06 ac 250 utility ign. switch problem
Old Aug 7, 2006 | 10:50 PM
ONEMUDDYRIDER's Avatar
Default 06 ac 250 utility ign. switch problem
has anyone had problems with engine dying with ign. switch in headlight on posistion, this is the second switch with same problem. if slightly move or shake key when in this posistion it will die. when switch was first replaced it would not die.
Old Aug 8, 2006 | 01:27 AM
Chumley's Avatar
I had to do a bit of rewiring with my switch. For me, it was the fact that the ignition wires are not routed in the most efficient way up to the cluster. I moved em around a bit to make a little slack and had to rewire a connector that had already been pulled apart. Since then no problems, but before it would die on me and eventually would not restart.
Try taking the ignition switch out of the instrument cluster and give the wires a little slack, see if the problem goes away. That should tell you if its the same problem I had.
Mkp
Mar 28, 2020 03:50 AM
green giant
Jul 13, 2017 12:07 PM
Mattius
Jul 11, 2015 10:44 PM
Bigredjeep
Jun 22, 2015 11:30 AM
wildbill59
Jun 9, 2015 02:28 AM
