Suspension
Old Oct 1, 2006 | 12:32 PM
JAT's Avatar
JAT
Default Suspension
How do you adjust the suspension on the artic cat 500. Do you need a special tool or what? I tried to turn it but it seamed to hard and if I was to put more force on it it would break the soft aluminum. And at what settings do you have yours on. Mine is on the first notch. thanks.
Old Oct 1, 2006 | 12:37 PM
BYBob's Avatar
Default Suspension
I have an 06 500 purchased bran new and it came with a tool. Looks like a hook. The shocks were factory set in the middle. I have not tried to move them seeing I like the ride the way it is.
Old Oct 1, 2006 | 02:50 PM
v2rider's Avatar
Default Suspension
You need a wrench for the shocks, or i think Bear uses something else like a big channel locks, but i would ask a nearby AC dealer for a wrench
Old Oct 1, 2006 | 08:44 PM
Williebee's Avatar
Default Suspension
Use a large pair of channel Lock plier's, the cheap aluminum tool that come's with the quad's are not stronge enough to do the job; i bent the one that came with my 400............williebee
Old Oct 1, 2006 | 09:38 PM
kaptap's Avatar
Default Suspension
Also, put a cooler or good jack under the a-arms to take the weight off them. It makes it a lot easier to adjust the suspension. The tool came in the owners manual bag, but I've heard they bend easy. So far, I've been lucky.
Old Oct 2, 2006 | 04:50 PM
Bear4570's Avatar
Default Suspension
If you use the supplied wrench, it's in the tool kit, you will break it (it's a cheap piece of crap), if you don't take the weight off the wheel being adjusted and lube it with DW-40 or some such lube. That's why I use Channel Locks, you can do it without lube and with the machine sitting on the ground. FYI, I tried mine set all over the place and ended up back where the factory set it. It suits my riding style best there.
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
