New to ATV- Flat tire preparation
Old 12-30-2006, 08:10 PM
Bear4570's Avatar
Default New to ATV- Flat tire preparation
Originally posted by: Crypto
Hey guys...will the slime damage the rims (steel or aluminum) ? The dealer told me to never put it in unless I have a flat?
He also said its a mess to change tires?
any thoughts
The Dealer is a moron. Slime can not hurt metal of any kind and it is water solubles, which means you can rinse it off with a hose if you need to take the tire off.
Old 12-31-2006, 06:35 AM
Crypto's Avatar
My thoughts exactly. Thanks
Old 12-31-2006, 10:29 AM
oldturtle's Avatar
Slime is not the best solution for every situation. Many punctures are too large for slime to repair, for instance a large nail or screw. Some of these punctures can be repaired on the trail with sticky rope plugs with extra cement. Once slime has contaminated a puncture then the sticky rope plug often will not hold. Slime will also cause difficulties when removing tire to patch from inside. Some side wall tears are not repairable. I carry the Walmart sticky rope plugs with extra cement, plyers to remove whatever caused puncture, and small 12 volt compressor. Top of the line 6 ply aftermarket tires such as Maxxis Bighorns are also good insurance. You can usually prevent tires from rolling off rim by just watching air pressure.
Old 01-02-2007, 12:50 PM
weez440's Avatar
another preperation you can do is get a stiffer tire. the itp 589's claim to be the toughest tire on the market for punctures. this doesn't mean they won't but i have put mine through hell and back. i did slice the sidewall once while spinning i think i hooked a nail or something and i drove back with ease the rim didn't touch the ground at all. but i would agree get some green slime
JackTheKing
Sport Quads
11-04-2019 06:06 AM
caveeagle
09-19-2015 01:20 PM
essonlaker
09-10-2015 01:12 PM
awer1968
09-08-2015 11:02 AM
MikeyBoyesq
09-07-2015 10:44 PM
Quick Reply: New to ATV- Flat tire preparation
