Striped Screws! need help
Old Jul 2, 2007 | 11:55 AM
Cman250's Avatar
Default Striped Screws! need help
I was replacing the belly pan on the AC utility and i striped a couples of screws, not just striped the head but it broke in half and part of the screw is still stuck in the frame. How should I go about getting out the screw so that i can put another one in? I was thinking of taking the dremle tool and just drilling out the old screw and put in a new one. Thanks in Advanced.
Old Jul 2, 2007 | 02:17 PM
billl2099's Avatar
if you can drill a hole in the center of the broken screw you can use a easy out, most hardware stores or local tool stores have them in diifferant sizes, should only take you a few minutes
Old Jul 2, 2007 | 02:18 PM
deanz400's Avatar
could try left handed drill bits and if that don't work ,use an easy out
Old Jul 2, 2007 | 05:27 PM
weez440's Avatar
drill it out bigger retap and get a bigger bolt if all else fails. it sux doesn't it.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Jackg17
Sep 26, 2015 09:30 PM
