Excessive Front Diff Play on '00 500Auto
Old Nov 3, 2007 | 10:52 AM
srponies's Avatar
Default Excessive Front Diff Play on '00 500Auto
I bought a project quad a while ago- '00 AC 500Auto. Have been working on the engine/trans and the brakes. Now I'm checking out the front end. How much play should there be in the front differential. What I mean is - should there be any lag between turning the driveshaft and the spinning of the front axles? I can spin the front driveshaft almost 180 degrees before the axles move. The previous owner disconnected the front diff engagement rod, too.
Should I just pull the diff out and apart, or is this normal clearance?
Thanks for any help,
Steve H.
Old Nov 3, 2007 | 10:06 PM
mudslinginfool's Avatar
Does it in the Mud!
sounds like alot to me. my bike is not here at the moment to check but i think it turns no more than an eighth of a turn. 180 seems alot. let me ask this, Is that with the bike already locked in 4x4 or do you lock it in then try turning it. because there might be a little bit of play before the diff. engages. but once engaged it should be no more than an eighth of turn i believe. hopefully someone else can help clearify this.
Old Nov 5, 2007 | 10:55 AM
srponies's Avatar
Well I pulled the front diff out today and took it apart a bit. Everything looks good inside. Nothing noteably worn and no broken parts. The amount of movement between the diff and the ring gear is controlled by cogs/fingers being inserted between slots, so there is no adjustment in the amount of play. Not sure if that makes sense or not. I did find that the rod going into the side of the diff that controls the engagement was binding and/or frozen to the side cover. That may of had something to do with the problem.
For now I'm just cleaning it up and reinstalling it with new fluid. Hopefully once I get it moving it will be apparent if it's working right or not.
Thanks for the help.
Steve H.
Bratman2
Aug 6, 2022 01:42 AM
carolinabomb
Jul 26, 2015 08:40 AM
carolinabomb
CAN-AM (BRP) Ask an Expert!
Jul 25, 2015 08:59 PM
TLC
Jul 25, 2015 02:24 AM
tporath
Jul 11, 2015 12:31 PM
