electrical
Old Oct 4, 2008 | 10:31 PM
MIKEY1981's Avatar
Default electrical
HELLO I HAVE AN ARCTIC CAT AND ONE OF MY HEADLIGHTS BEARLY COMES ON IN EITHER BRIGHT OR LOW POSITION IS THIS A BAD GROUND OR WHAT? WHERE DO I START? THANKS
Old Oct 5, 2008 | 03:46 AM
HeftyLefty's Avatar
Default electrical
More info needed-model? year? auto/ manual?.
Old Oct 5, 2008 | 02:53 PM
MIKEY1981's Avatar
Default electrical
HELLO AND THANKS FOR THE HELP, MY CAT IS A 2000 MODEL 300 4X4 MANUAL SHIFT IF YOU NEED ANY MORE INFO JUST TELL ME WHAT YOU NEED. MIKE
Old Oct 5, 2008 | 09:25 PM
HeftyLefty's Avatar
Default electrical
Check weak light side for chafed wiring, it's probably grounding somewhere. Also, check the bulb housing for corrosion, make sure housing is fully grounded..
Old Oct 5, 2008 | 11:28 PM
MIKEY1981's Avatar
Default electrical
HELLO AND THANKS WILL DO ASAP
Old Oct 6, 2008 | 06:20 PM
swampyjunior's Avatar
Default electrical
I have one light that does that too and when I unplug it the connector plug has gotten water in there and rusted the connections. I had to use a tip of a knife and scrape it clean to et it to work correctly again. If that did not work I was going to change out the plug.
SJ
Old Oct 6, 2008 | 11:34 PM
MIKEY1981's Avatar
Default electrical
HEY THAT SOUNDS LIKE A REAL POSSIBILITY WILL TRY THAT FIRST. THANKS FOR THE HELP
ReconBayou
Oct 31, 2022 05:37 PM
EIF
Apr 20, 2017 07:15 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Sw00p
Sep 24, 2015 02:50 PM
