Rear axle
Old Nov 15, 2008 | 07:29 PM
sassee's Avatar
Default Rear axle
how hard is it to replace right rear axle? I have an AC400 and the right rear axle shaft broke about 2 1/2 inches in. It messed up a couple other things but the axle is the biggest problem.
What all is involved with swapping the axle since I've never done one on an ATV before. (plenty of trucks and jeeps though)
Ernie
Old Nov 15, 2008 | 08:09 PM
WarBirdMech's Avatar
Default Rear axle
axles are easy. remove the hub and the axle will pull out of the diff with a sharp yank. its held in by a circlip. putting the new one in is as easy as lining up the splines then while pushing in on the axle give it a few lite taps with hammer
Old Nov 17, 2008 | 09:14 AM
sassee's Avatar
Default Rear axle
Well the hub kinda came off with the wheel! (along the the bracket for the rear brake cable and a couple smaller things that broke in the process!) the axle shaft is about an inch and a half inside the housing so there is no grabbing hold of it. Do I now have to take the axle housing loose at the differencial housing?
Also, any good place to buy an axle cheap? (good used one is what i'm looking for)
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
