Stuck Drive Axle Nut
Old Nov 27, 2008 | 02:33 PM
reassembler's Avatar
Default Stuck Drive Axle Nut
I have a 2007 Arctic Cat 650 H1.
I'm need to replace a boot on the rear drive axle. I can't get the lock nut on the drive axle to budge.
Anybody have ideas?
Old Nov 27, 2008 | 03:26 PM
swampyjunior's Avatar
When I take mine off once a year to check the seals and bearings I usually soak the P-wad out of it with penetrating oil like WD-40, liquid wrench or the like. Then I let is sit over night. The next day I put the "metric socket" that I bought to fit it the hex nut in my impact wrench and it usually comes loose. The first time I had it off I had to let it soak for a second night.
It may help if the machine is left in gear and the opposite tire is on the ground so the axle will be less likely to spin. I think the socket was 27 or 28 mm and was the best $10 I have spent on special tools in a while.
When you get it off the hub and you go to re-install it put some Anti-seize on the threads. Do not put too much as this attracts dirt which traps water and can cause rust.
Also if you need a good HD CV boot check out the website thecvman.com he sells HD boot kits that are awsome. I am currently using several and the kit comes with everything you need, is cheaper than the dealer AND has a set of very detailed instructions for the inner and the outter CV-boot. IF you already have the boot then you may want to take a look at his instructions as I have found them to be very good, except no pictures.
SJ
Old Nov 27, 2008 | 09:49 PM
CatKrazy's Avatar
A good penatrating oil.
Also tap/hit the axle nut, to break anything loose in there. Use a impact 30 or 29mm socket i believe. they have them at Oreilys.
When I re install all my bolts, I use anti seize.
Old Nov 28, 2008 | 08:23 AM
thanks for the advice. i tried penetrating oil, before, but i only let it sit about 15 minutes [img]i/expressions/face-icon-small-sad.gif[/img] i'll spray it and let it sit overnight this time.
Thanks again, Dave
Old Nov 29, 2008 | 09:02 PM
brad_smalley's Avatar
ive replaced two boots on mine and had troulbe getting the nuts off can anyone tell me the size socket i need and i will get one so i cam use my impact gun
Old Nov 29, 2008 | 09:49 PM
mine is 30mm
Old Nov 29, 2008 | 10:57 PM
CatKrazy's Avatar
yep 30mm, had to take mine off today.
When you go to put it back on, use anti seize on the threads
Old Jan 23, 2009 | 10:21 AM
Just a follow up. I tried the penetrating fluid over a period of 2 days and it worked like a charm. I replaced the boots and the PITA boot clamps and now she's rolling again.
Thanks for the help.
Dave
Old Jan 23, 2009 | 06:06 PM
Good to hear you are running again. I also forgot about applying a liberal coating of antiseize before putting it back on. I take mine off once a year to check/replace the seals and they just are not that difficult to get off after the first time. I find it cheaper to repack the bearings and repalce the seals ar $4 each rather than a bearing for $40. Dang mud packs in there and takes the seal out then water gets ito the bearing and it is done for it.
I purchased an automotive CV boot clamp tool (was about $35) and it is a very handy device. The bands are cheap (about $2-$4 each) and the tool makes it way easier than messing around with a pair of pliers as some guys try to do.
SJ
scram5050
Aug 30, 2024 01:39 PM
Polaris5
Aug 29, 2015 09:11 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
ghost civic
Jul 15, 2015 10:48 PM
