2000 400 4x4
Old Nov 27, 2008 | 07:11 PM
wild boar's Avatar
Default 2000 400 4x4
HI everyone, new to forum and this is my first atv. The problem i am having is that after i ride it for 10 min. or so it starts to run bad and stalls out and will not restart until i let it sit for 10 min. or so. I dont know if it has something to do with the choke or not, but it will only start and run with the choke lever in the up posistion. When the lever is up is the choke on or off?
Thanks in advance.
Old Nov 27, 2008 | 09:45 PM
CatKrazy's Avatar
Check filter, clean,replace if necessary. Also check the carb vent hose (the top hose coming out of carb) and make sure the hose isnt kinked.
Old Nov 27, 2008 | 11:14 PM
cherokee99's Avatar
clean your carb well, i think the choke is on when its UP. but if it starts/runs fine at first, but then after rideing for 10mins it wants to shut off that could be serious. i have an 99AC 400, same basic symptoms. after i ride it for 20mins iv got no more throttel and it will slowly putter out til dead. i know mine has a burnt exhaust valve, it ran a little lean for too long of a time.
try cleaning the carb, i really hope that helps
Sisco1957's Avatar
Up is the off position. Down pulls the cable and moves the choke valve. Sometimes an electrical part will break down after it is run awhile. When it stalls are you still getting a spark? Could be the coil. Thanks.
Old Nov 28, 2008 | 12:18 AM
wild boar's Avatar
ok so i should clean the carb and ckeck for spark when it sputters out and backfires. So the choke lever should be UP when riding?
thanks for the replys!!!
Old Nov 28, 2008 | 11:26 AM
Sisco1957's Avatar
Have You tried a new spark plug. It's easy to overlook the simple things sometimes. Could the carb be running to rich? Usually You have to choke a cold engine to start but sounds like You never have to on yours.
Old Nov 28, 2008 | 02:07 PM
wild boar's Avatar
I pulled the plug this morning and it looked wet and had a glossy black color. I cleaned it and let it ran until it started to die, pulled the plug again and it was the same. Also found a line comming fron the right side of the carb. to the left that is not connected to anything, it has a small squeezable clamp on it. Where should this go? its hanging right below the fuel intake line at the carb.
Old Nov 28, 2008 | 05:40 PM
CatKrazy's Avatar
Thats your carb vent hose.
Was it pinched, or kinked?
Old Nov 29, 2008 | 10:33 AM
wild boar's Avatar
no it was not kinked. My dad is going to pull the carb and give it a good cleaning today.
My tail light bulb is missing does anyone know what size bulb i need to get. sorry for such a stupid question but my dad has a manual on order and it has not come yet.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
Gwolf228
Feb 18, 2017 01:36 AM
Dammar
Apr 20, 2016 06:03 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
