Decal Removal
Old Nov 30, 2008 | 10:57 AM
crzrlou's Avatar
Default Decal Removal
I recently purhased a 2003 250 4x4 and it has all kinds of warning and safety decals on it. I don't need them on there and I think it really cheapens the looks of the vehicle. Does any one know a way to remove them without scratching or damaging the plastic. Thanks for any info. Lou
Old Nov 30, 2008 | 12:16 PM
HDTRIGGER's Avatar
heat them a little bit with a heat gun/hair dryer and then try lifting a corner with your fingernail and then they should pull right off.im a autobody tech, so i would either use my stripe remover or just use a standard single razor blade.but probably not a good idea if you have no experience with stripes.decals with razor blade, so just use method one. and if theres any glue residue left behind just soak a rag with alcohol and saturate the glue pretty good before you start rubbing it off.
Old Dec 1, 2008 | 12:49 PM
bighweel366's Avatar
The best way and probably the easiest is called a pressure washer. Crank the PSI up and they will come right off with out scratching or damaging your fenders!
Old Dec 1, 2008 | 03:02 PM
crzrlou's Avatar
Thanks for the info about the heatgun. I have one so I tried that and it worked great. The decals came off fairly easy after they were hot, then I used a little gas on a rag to get the glue residue off.
Old Dec 2, 2008 | 02:07 AM
HDTRIGGER's Avatar
glad i could help
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
