1999 400 4x4 starting issues
Old Nov 28, 2009 | 06:20 PM
400 artic cat's Avatar
Default 1999 400 4x4 starting issues
I have a 400 Artic Cat 4X4 that will run as long as the starter in engaged
but as soon as you release the starter button it shuts down just like you turned off the ignition
just to test I held the button longer and revved up the engine
it sounded fine ( except for the starter noise ) but again as soon as I released the starter button it dies
can anyone help ??
does any one have a wireing diagram ??
Thanks in advance
Old Nov 28, 2009 | 11:14 PM
Default further test
since the starting system should be completely seperate from the ignition system I pulled the wire from the solinoid that runs to the starter to isolate the starting system
still when I touch the wire to the battery with the key on
it will start but as soon as I remove the cable from the battery
it still turns off just like I turn off the key
Old Dec 5, 2009 | 12:29 AM
Bobmack's Avatar
test the starter relay
chinkapin
Jul 14, 2016 06:58 AM
buckshit
Sep 24, 2015 08:49 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
1000gade
May 27, 2015 12:37 PM
bigrobzxxx
Oct 2, 1999 10:01 PM
