2000 Ac Transmission problem
Old May 27, 2010 | 07:39 PM
pooleb's Avatar
Angry 2000 500 Ac Transmission problem
2000 500 Ac auto Transmission problem will not move in any gear seems to shift but does not move .I took clutch cover off and and ran the bike and all looks good there
Thanks Bob
Old May 31, 2010 | 11:52 AM
DaveofHutto's Avatar
You are going to have to pull the rear end, drive shaft and take the transmission cassette out. Take about 2 hours with simple hand tools.
Before you do that make sure the shifter is attached to the shaft and is moving the shift shaft.
Old Jun 1, 2010 | 06:11 PM
pooleb's Avatar
thanks for the info .can i do this without removing the engine .and does the transmission cassette come out the back of th engine or behind the back clutch.
thanks Bob
Old Jun 13, 2010 | 11:24 PM
Best bet is to buy a down loadable manual from midwestern manuals. You start by boning up on it and looking at your ATV.
Old Jul 4, 2010 | 03:38 PM
pooleb's Avatar
well i got it fixed there was a broken gear on the output shaft it also broke part of the case .you half to split the engine but it wasn;t to bad just need to keep tapping on the shaft when you pull it apart so everything doesn;t fall out.i got a used bottom end from a guy and swaped it out a had a noise coming from the transmission took it apart again and discovered the bearing on the output shaft needed to be replaced i guess thats what was wrong with the bottom end i bought
Old Jul 5, 2010 | 01:07 PM
Did you do it with or without a manual?
Getting the drive shaft back into its housing with the spring. I just put grease into the socket and the spring into the grease. The rear end as a unit is heavy, for me it is, I used tie downs to support it to the ATV frame while aligning the drive shaft to the output shaft and installing the swing arm pins.
Old Jul 6, 2010 | 05:12 PM
pooleb's Avatar
I had arctic cat manual i pulled the engine and split it on the floor. I looked at your pics of your 250 there not the same you have to split the engine up the center to get at the transmission on the 500. P.S the arctic cat manual is not that great doesn;t give enough details
Old Jul 6, 2010 | 07:13 PM
The AC manual is pretty lame. On the 250 they have you trying to disassemble the tranny as it sits in the "fixed" half.
This is the half that is part of the engine. The tranny is a "cassette" type and there is no way you can disassemble and reassemble the unit as it is written in the book. The biggest issue I have is placement of the thrush washers. I used a online mirco filtch to get the correct placement. So far I have had the tranny in and out of the cassete 10 times to figure out how to reassemble it and in and out of the fixed half 8 times as I can not get nuetral to work. I get forward and reverse. I may have a thrush washer in the wrong position. The last time before I called it a day I could not get it to go into gear. I get to take it back apart and try some thing else. So the tranny comes apart again, Relocate a thrush washer. BTW the micro filtch is not that good either.
Old Jul 7, 2010 | 08:27 AM
pooleb's Avatar
Good luck I think the thrush washers are defferant thickness this may be your problem did you keep them in the same order they came off?
Old Jul 8, 2010 | 04:03 PM
The I.D. are different. Between the time I pulled it apart and the time I started putting it back together, I slept many times.
coolguy420
Jul 10, 2015 01:17 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
Mikea1978
Jul 4, 2015 12:37 PM
bikedad3
Jul 2, 2015 02:15 AM
