06, 400 Artic Cat automatic 4x4 will not engage
Old Nov 13, 2010 | 02:57 PM
Prossygk's Avatar
Default 06, 400 Artic Cat automatic 4x4 will not engage
I have a 2006 Arctic Cat 400 automatic 4X4 that the 4 Wheel drive will not engage but when I hit the switch it says it is in 4 wheel drive on the screen but there is no whirling sound. i have had it off the ground and tested to be sure and the front wheels are not moving. when the switch and 4wheel drive indicator on the display says it is engaged but still no luck. . Is it the actuator or something else?. Can anyone help me?
Thanks
Prossygk
Old Nov 13, 2010 | 06:21 PM
Fossil's Avatar
"If you haven't any charity in your heart, you have the worst kind of heart trouble." ~Bob Hope
Likely the actuator. Remove it and take it apart to see if water and mud are getting in there. If so, clean it up and seal the housing with silicone when you put it back together.
Hopefully it still works.
Old Jan 16, 2011 | 09:00 AM
Scotty G's Avatar
Default 2005 Artic Cat 400 4x4 auto, same problem
I brought it to AC dealer and he said it was the actuator, had him install new one, took it home still no 4x4, please let me know what you find out
Old Jan 20, 2011 | 09:44 AM
07 400's Avatar
check and see if you are geting voltage to the plug that goes to actuator. if you are that it is the actuator. if not you could have a bad switch or a fuse or relay under seat.
Old Jan 20, 2011 | 06:45 PM
Scotty G's Avatar
Thanks 07 400, I will check that
kodiacrunner
Oct 4, 2015 11:52 AM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Coondoog
Technical and How-To Articles
Sep 9, 2015 01:51 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
