arctic cat stuck in limp mode???? help!!!
have a 06 tony stewart edition 650 v twin. just put new instrument cluster in cause when i bought it was busted. right when i turn on speedo needle goes all the way up and down about 6 or 8 times. while belt light flashes the whole time.
dn't know much about them at all. any hlp or ideas would be great.
thanks
thanks
You have to go to arctic cat and get the jumper wire plug to reset belt light. after you reset the light and it comes back on you might have to take belt cover off and flip switch. then if it keeps put belt light on you may need a new belt. some of the older ones had a filter because the interferance with electrical
Jeff Roper
Feb 1, 2022 11:48 AM
mrtidy
Feb 3, 2016 05:00 PM
