I think its a carb issue
Old Mar 11, 2011 | 09:31 AM
tex599's Avatar
Default I think its a carb issue
My 04 250 has been sitting for a month since I burned up the CDI, Voltage regulator and coil. I replaced it, redid the melted wires and it started right up yesterday. It ran fine with the choke on, but once turned off it would die. Sputtered the next few times I tried to start it, but now it will not start, turns over fine. It ran fine before all this happened. I checked for spark and it was there. Leads me to believe fuel issue, if it were a wiring issue I don't think I would have spark, correct? Any thoughts?
Old Mar 11, 2011 | 01:57 PM
Jaster94's Avatar
clean the carburetor/jets...........
Old Mar 11, 2011 | 06:53 PM
Kerbbirds's Avatar
pilot jet plugged in carb
Old Mar 12, 2011 | 11:03 PM
tex599's Avatar
If the stator is bad what are the symptoms?
Old Mar 13, 2011 | 10:09 AM
fireman712's Avatar
I think it your your jets lke kerrbbirds said. I had a 250 done the same thing open the jet up ran find.
Old Mar 16, 2011 | 05:16 AM
Jaster94's Avatar
still a carb issue like it's been stated.........but what concerns me is that you've burned up some of the voltage system. hmmmmm, i wonder what has gone awry? crossed wires, grounding issues, electrical surge? accidental mismatch on battery posts? mismatch if jumping of the quad from a car battery? hmmmm....don't read nothing into my words, just thinking out loud to eliminate possibilities. i'm just trying to figure out how that stuff burned up.
Jmuddin284
Jan 19, 2026 07:16 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
Mikea1978
Jul 4, 2015 12:37 PM
