Arctic Cat 4-Stroke 90cc everything
Old Jun 15, 2012 | 05:33 PM
Dawn14320's Avatar
I found the screw! Now it still won't start! It tries and tries but it just wont start! I have tried everything but get inside the motor... I am tempted to do that though! I am frustrated with it! Anything else I can try... could the intake get clogged up?
Old Jun 15, 2012 | 07:40 PM
Dawn14320's Avatar
One more big problem, I now have no power. Well, I have power to the brake light but when I turn the key and try to start it nothing. Is this a bad thing? Is it the starter?
Old Dec 24, 2013 | 10:41 PM
Coz's Avatar
Coz
Originally Posted by Dawn14320
I took pictures as I took the screws out, until I turned it upside down and 3 little pieces fell out of the outside of the hole on top. Is this going to be hard to get back together? I am soaking it hopefully gasoline is right cause if not then my husband is a complete idiot. I have done everything to this point. I may need help with the putting the carb back together. Detailed help... we will see in a few hours how it goes! Any suggestions on the easiest method or order to do it.
I've been beating my head against the wall for weeks with my sons artic cat 90 2x4 2 stroke . It has spark , it's getting fuel . It runs . At times it bogs out as if it ran out of gas . Cleaned carb / changed spark plug . Ordered new ignition coil . The are two outputs from the gas tank . 1 to the carb , 1 capped with a screw. . The petcock is missing . There is a fuel filter coming from the motor but where does the other end connect to ? Any suggestions . I'm thinking a short in the ignition system , that line from the motor to nowhere or something else electrical. New battery on order as well . Any suggestions would be helpful. ...
Customer Service #1
May 15, 2020 08:46 AM
brad patnoe
Sep 23, 2015 06:44 PM
Chasso
2) Chassis problems..
Sep 19, 2015 03:06 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
vtech
Help With Forum Software!
Sep 2, 2015 05:59 PM
