Need help on 2000 duramatic clutch
Old Feb 17, 2014 | 06:43 PM
KennyBvn's Avatar
Default Need help on 2000 duramatic clutch
Disassembled the primary clutch. My question is this, does the inner dicks of the primary clutch have a bearing in it? The bike is a 2000 or 2001 RED Artic cat 500 automatic with a duramatic clutch. The bike wont change gears when its running. Its not the cable or shifter and the clutch seems fine other than I don't know if that inner primary should have a spinning centre. Would that cause the bike not to change from backwards, forward etc. When the bike is not running it will shift. I'm thinking if that is a ceased bearing on the inner plate of the primary that might cause it to be under load when idling? I can't find a diagram of the clutch anywhere to see if that is a ceased bearing on the inner plate. Other than that the clutch seems fine. Please email me at Kenboivin@msn.com with input or diagram link
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
