leaky carb
Old Mar 2, 2015 | 07:29 AM
kendogu's Avatar
Default leaky carb
I bought my first used cat a 06 4x4. It's got push button 4or 2 drive. The carb . I am new to these beasts and treat them like my kids. So when I bought it I checked compression. Brakes rode it for about 5 min. And loaded it. Because of the leaky carb. I cleaned the carb needle seat and main needle jet. I cleaned every nook and cranny . It's leaking from the drain screw.I know it serves dual purposes,thanks to the people on this site and artichat. So before I put it back together again I checked the drain screw function that actually drains the bowl. Installed a inline fuel filter from tank to carb. And checked the float seat simply by blowing through the gas inlet and flipping carb in hand upside down. My question is this,can the primer pump on the right side of the carb have any thing to do with the carb still leaking? Also if I have to replace the carb what model is mine? It's a 2006 400 4x4 shaft from front to back. Manuel trans I dnt believe it has a belt. Lighted digital Speedo. Disc brakes. I noticed a couple online but I don't know. I appreciate your time and knowledge. Thanks
Old Mar 2, 2015 | 07:48 AM
You can't visually inspect a carb float needle for wear. Just install a carb kit and go from there. Yes the drain screw leads to the bowl,plus this hole at the bottom of the carb also incorporates the overflow. Even if the float level is set right,a worn needle and seat can cause it to leak and overflow.http://www.ebay.com/itm/REPLACEMENT-CARB-REBUILD-REPAIR-KIT-ARCTIC-CAT-400-FIS-2X4-2004-400-4X4-04-05-06-/231233046828?pt=Motors_ATV_Parts_Accessories&hash=item35d690492c&vxp=mtr
Old Mar 2, 2015 | 08:49 AM
kendogu's Avatar
Default title
Thanks opt. Does anyone know what model mine is for the purpose of ordering parts? I have the title and decoded it. Just says 06 arctic cat 400. But there's 2 or 3 different manual models. Thnx
Old Mar 2, 2015 | 10:07 AM
Maybe this can help you narrow it down..OEM Parts : Babbitts Arctic Cat Parts House
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
