2003 400 auto starter problem
2003 400 auto starter problem I replaced the flywheel and stater on my 4 wheeler and seemed to go well but the starter will only crank when I loosen the side cover .I checked and the washers are in rite I did use gasket maker instead of a gasket could the thickness of a gasket make that much difference?
Thanks Bob
Thanks Bob
I know tolerances can be very close, so it would be worth it to try the AC factory gasket. Did you torque the flywheel nut down to factory specs? If it turns over, when you loosen the cover fasteners, must be only a wee bit. You have a repair manual, right? Maybe got something spaced out wrong?
I've narrowed my choice for 1st 4 wheeler down to two: AC 400 4x4 auto and Suzuki Eiger 400 4x4 auto
John3
Feb 1, 2004 03:15 AM
John3
Aug 22, 2003 07:03 PM
landover
Oct 16, 2002 11:52 PM
