2005 arctic cat 500 4x4 issue
Old Aug 11, 2019 | 12:52 PM
Wes76311's Avatar
Default 2005 arctic cat 500 4x4 issue
When I'm riding on a trail or anything I cant get it to go past half throttle. It acts like its choking out. I've cleaned the air filter new fuel filter and used Seafoam in it with premium gas. Any other ideas what it might be? It runs great otherwise at lower rpm.
Old Aug 11, 2019 | 08:42 PM
Kymco 450i's Avatar
I would start with a good compression check to tell the health of the engine. If that is good then how about a new plug. If your only cleaning the carb with a fuel cleaner additive that may take some time and many tanks of fuel.
Old Aug 11, 2019 | 08:50 PM
Wes76311's Avatar
Very good I'll check the compression. I did look at the spark plug and it looked good but I'll put a new one in and see if that helps. The machine has 1100 miles on it so didnt think the compression should be an issue but guess you never know. I bought it it used. Thanks
Old Aug 13, 2019 | 09:44 AM
Zrock's Avatar
Super Quad Patrol
A 2005 with 1100 miles on it has had alot of sitting time. My bet is the carb is gummed up and needs to be dissembled and cleaned a por in the tank carb cleaner is never going to get those hard deposits out of the carb
bg2112
Oct 14, 2010 11:50 AM
rick1410
Oct 1, 2009 02:58 PM
sulfar
Feb 9, 2009 08:49 PM
4paws
Jul 27, 2008 01:12 AM
brad_smalley
Aug 22, 2007 11:08 PM
