H1 belt slipping
Old Oct 21, 2019 | 12:13 PM
Alex G.'s Avatar
where did you buy your belt from?
Old Oct 21, 2019 | 12:22 PM
neub7's Avatar
I'm going to replace the rollers in the primary and hope that works. When I opened up the cover after the belt came apart the primary was open and the rollers were rattling loose. They probably took a beating. A few of them have nicks and scratches but nothing drastic. I'm not sure how bad they can be scuffed up and still be OK.
Old Oct 21, 2019 | 12:24 PM
neub7's Avatar
Bought the belt off amazon from a private seller. I'm wondering if it's not a defective belt.
Old Oct 21, 2019 | 01:07 PM
Kymco 450i's Avatar
Could be a mismarked belt....there should be a deflection measurement for the belt when mounted on the clutches, this might give you a clue as to whether you have the right belt.
Old Oct 21, 2019 | 02:25 PM
  #15
Alex G.'s Avatar
What is the part number on the belt?
Old Oct 21, 2019 | 04:15 PM
  #16
neub7's Avatar
Old Oct 21, 2019 | 04:17 PM
  #17
Alex G.'s Avatar
Is that from the actual belt? Or the oackage?
Old Oct 21, 2019 | 05:22 PM
  #18
neub7's Avatar
The package. Belt is on the machine with the cover still on. Didn't have time tonight to take the cover off.
Old Oct 22, 2019 | 07:39 AM
  #19
Alex G.'s Avatar
And not to question your abilities, did you know that there is a direction arrow on the belt to make sure you put it on correctly?
Check the number on the belt when you get a chance...
Old Oct 22, 2019 | 08:07 AM
  #20
neub7's Avatar
Feel free to question my abilities. Lol. That's why I'm asking. I'm not a mechanic. I know a little bit, and have Google and youtube. As for your last question, yes. I put the arrow pointing toward the rear of the machine. Towards the primary. I'm beginning to wonder if it's not a wet clutch issue just by processs of elimination. I know nothing about the wet clutch at all. When it's slips it makes a squealing sound like the belt if it were slipping. 2 questions... If the wet clutch were slipping would it make a squealing sound like that, and if the wet clutch were bad could it cause the belt to slip for some reason?
