300 Arctic Cat engine problems
Old Jun 19, 2001 | 11:08 PM
NewHollandRules's Avatar
We bought a 2000 300 Arctic Cat 4X4 last year. It's been fine so far only a few electrical gliches. Anyway, the four wheeler has about 2500 miles on it and the engine doesn't want to run when the choke is applied at all. When it's cold it's the worst. Also it smokes and uses oil. We use it everyday being on a farm and such. I have never seen an being new have these kinds of problems in less than a year. Hope someone can help me.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 20, 2001 | 09:49 AM
sxr6's Avatar
What do you mean " doesn't want to run with the choke on ", it's not supposed to unless it's cold. You didn't but chance run it for a day with the choke on, that'll wash the rings and hurt the engine!!
Old Jun 20, 2001 | 05:40 PM
The only time we ran it on the choke was when it was cold like your supposed to do. Now when you put on the choke it dies. Another thing, will a/c cover the entire cost for rebuilding the engine since it's using oil, we bought the two year warranty.
Old Jun 21, 2001 | 10:11 AM
kukerdan's Avatar
YOUR NOT SUPPOSED TO RIDE IT ON THE CHOKE,]
that will kill your engine!
your supposed to use the choke to get it started.......
Old Jun 21, 2001 | 06:57 PM
Copper's Avatar
It sounds like your rings are gone. I would take it to your dealer and let them check things out. If the temperature is above 50 I don't even use the choke on mine when I start it up. It starts as soon as the starter hits. If its cold out I only choke it half way and it starts fine. As soon as the engine warm up I open the choke all the way and ride. Good luck and hope this helped.
Old Jun 22, 2001 | 09:25 AM
sxr6's Avatar
You said when you put the choke on it dies, if it's already running why would you put the choke on?
neilbedwell
Nov 10, 2018 11:02 AM
chinkapin
Jul 14, 2016 06:58 AM
backhoelover
Jun 26, 2015 12:21 PM
butcho4prez
Jun 23, 2015 09:30 AM
kevbowe
Jun 1, 2015 01:17 AM
