need help removing axel from AC454
Old Jul 9, 2001 | 01:58 PM
bearcat454's Avatar
I am in the process of trying to remove my axel, everyone tells me to jerk it real hard, I even went to auto zone and got a slide hammer but it still wont come out, can anyone tell me some trick or something to get it out.Thanks!!!!
Old Jul 9, 2001 | 02:22 PM
Bigdcred's Avatar
front or back, if it is the back you need to take the housing assembly off from the third member. (the big ball that the Axel attach to), there should be 4 bolts that hold it on you will need to take off the skid plate and tow hich, then the hole thing falls of and the Axel comes out.good luck[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 9, 2001 | 05:39 PM
bearcat454's Avatar
sorry, didnt make myself clear, im trying to get the front axel out of housing, everyone says to jerk hard but it just wont pull out
Old Jul 9, 2001 | 11:49 PM
scotto's Avatar
Keep working at it with your slide hammer. If it's a 454 and you never had it removed then it must have been on at least 4 years. Keep working at it it will come off..
Old Jul 10, 2001 | 10:16 AM
zrt1000's Avatar
I had big problems getting one out of my 454, I tried the slide hammer and still could not get it off. I ended up taking the cv apart to get to the axle stub that sticks out of the dif. then welded 2 blocks of steel on either side of the bell for the cv and used a puller. It came off but it pulled off the splines on the end of the axle stub, It worked fine after putting it together.... Bill
Old Jul 10, 2001 | 11:57 AM
minehunter's Avatar
This may sound kind of corny to you, but here goes. For awhile I was in the Navy and part of that time I was an Aircraft Mechanic. We would run into stuck splines and such all the time from parts being exposed to different weather extremes and such. Anyway to get to the point, we used Oil of Wintergreen to get them to loosen up. I believe you can get it at drug stores, just ask the pharmacist. Be extra careful with it because it is POISONOUS. Just use it like you would penetrating oil, let it soak for a couple of hours, then back to that slide hammer. Good luck.
Old Jul 10, 2001 | 11:57 PM
bearcat454's Avatar
Finally got it off, Had to weld my puller to the hub and use puller. It did chip off a peice of the shaft but still works. Thanks zrt1000, i dont believe it would ever have come off with a slide hammer. It had been on too long.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
clscott84
Sep 21, 2015 10:16 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
