Thermostate for 400 AC
Old Jul 23, 2001 | 01:00 AM
Cromwell's Avatar
Has anyone found a good engine temp gauge for the 400 AC? I just purchased my ATV and I want to know how hot that antifreeze is when I'm riding.
I also want a fan switch that only runs the fan when the engine is hot enough to need it.
Thanks for your advise.
-Charles Cromwell
Old Jul 23, 2001 | 04:47 PM
ttaylor's Avatar
I am not sure who makes the best temp gauge. I know that Highlifter sales a kit. Seems like it was around $100. My brother-in-law works for AutoMeter. They make the gauges for NASCAR. He got me one of their smaller units with a 3/4 read out (meaning that the numbers go 3/4 the way around that gauge). I haven't installed it yet. So I can't give you any temperature readings. I should have it installed within the next few weeks. Summer time is too busy for me. I just work hard and ride hard!!!! [img]i/expressions/face-icon-small-happy.gif[/img]
For the fan switch. I have installed an on/off switch. I just turn off the fan when I cross deep river crossings. for me the fan is so quiet I don't even hear it running. It would be nice to have it temperatured sensored. Let me know when you get it done. I would be interested in knowing how you did it.
Old Jul 24, 2001 | 12:34 AM
BONER's Avatar
Grizzlyrules has the High Lifter temperature guage that sells for $89.95. The way his was installed ( you have to cut into a hose to install the sensor-- you can cut into the return or feed hose from the radiator-- its your choice) he is telling me his runs at around 115-125 degrees. So, that HAS TO be from the return of the radiator if you ask me.
Old Jul 24, 2001 | 10:21 AM
sxr6's Avatar
What about the temp switch from earlier Cats, my buds 99 500 fan kicks on & off according to engine temp. Let me know how you make out as I think a new 400i is in my future.
Old Jul 28, 2001 | 05:05 PM
BONER's Avatar
There is a reason they removed the temperature switches, they fail. Mine failed causeing my fan to almost never run except for when going up an incline while hot. So,l I had it wired direct and I installed a fan switch later.
Old Jul 28, 2001 | 07:51 PM
mudcat47537's Avatar
They went back to the temp activated switches on the 02 models. I liked it on all the time, but with a switch to turn it off in the deep stuff. The 02's seem to run a lot more ( come on at a lower temp ) than my old 98 did it hardly ever came on.
rockey07
Jun 17, 2009 10:55 AM
simonsen
Jul 7, 2008 10:11 AM
mxzxracin
Apr 15, 2005 12:08 AM
