Warn 2000lb or 2500lb
Old Aug 24, 2001 | 11:59 PM
StitchZR2's Avatar
Im going to get a Winch this next week!!! Im not sure which one I should get. I see that the 2500 has a really nice switch that mounts under the on/off switch of the AC's. It really looks nice does it still come with the 6ft cord so that you can stand away while working, also how many of you guys wish you would have went with the 2500. I see they have a upgrade kit, but it looks to be cheaper just to buy the 2500 up front. The best price that I can find is 399.99 for the 2500. Anyhelp would be great.
Thanks
Old Aug 25, 2001 | 09:13 AM
bearcat454's Avatar
if you check the specs on both the 2000 and 2500, you will see they both use the same motor, just the controls are different.
Old Aug 25, 2001 | 11:11 AM
dakotart's Avatar
The 2500 uses heavier guage wire and switches. More current can pass through and drive the motor more. Motors and cables are the same. 2500 also comes with the roller fairlead. Big plus for weird angle pulls and tugs.
Old Aug 25, 2001 | 03:43 PM
StitchZR2's Avatar
I called a few of the local dealerships and they all had the same prices
Warn2000 396.99
Warn2500 469.99
And then the Warn2500 from AC is 399.99 and that also comes with the roller fairhead, it comes with a switch that mounts under the on/off switch for the AC's. But it does not come with that 6ft. control cord with the joystick. I dont think that the 6ft control cord w/ the joystick is worth $70. I think Im going to go with the AC-Warn2500.
Thanks
Old Aug 25, 2001 | 07:02 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
I have a new in the box 2000LB WARN (has the roller fairlead and all wiring) I wnat to sell ($300). jweide@coair.com.
Old Aug 28, 2001 | 04:17 PM
BilltheDog's Avatar
I bought a Warn 2500 from www.atvpartsdepot.com a little over a month ago for $349. I see now it sells there for $365. The roller fairlead is included, but the mounting plate specific for each ATV is extra. It does have a 6ft. cord and attached to the paddle switch.
Old Aug 30, 2001 | 01:11 PM
StitchZR2's Avatar
I got it the other day. I paid 450 with the mounting plate for the 2500 with the AC logos on it.
Thanks for all the help.
Im going to be installing it tonight
Thanks
Jeff Roper
Feb 1, 2022 11:48 AM
toonces
Oct 19, 2015 02:21 AM
panicmanic
Sep 28, 2015 12:59 PM
Erick J. Edler
Sep 20, 2015 05:51 PM
Gtsordo
Jul 22, 2015 01:27 PM
