Want some new Arctic Cat products?
Well if you want then you have to work for them.
I have been trying to talk a few aftermarket companyies (Supertrapp, Highlifter, Progressive Suspension, Twinn Air, etc.) into making more products Arctic Cat products,BUT I NEED YOUR HELP.
I can't do it alone, they need more people to bug them about getting products for Arctic Cats.
Go to:
WWW.HIGHLIFTER.COM
Go to:
WWW.HIGHLIFTER.COM
Hey Rob,
Have you gotten any word on new products for the 300 4x4 or release dates(Lift Kit). I know Rocky Mountain sells the K&N Filter and Jet Kits for the 300 but not as a performance kit, you have to buy each seperately. High Lifter does have some 1.5 spacers for it too, i think for $140, not sure.
Well High Lifter is gonna hold off on the AC 300 lift because they are moving into the new building. It SHOULD be out before the summer-- but not sure.
I am working with a couple of companies to get a Metal skid plate out there. I Will also TRY as hard as I can to get one of them to make an adapter to add an oil cooler to the semi-irs models. I think this would be a great thing for these models.
The AC300 could maybe use a larger oil cooler, but I would need to ask you 300 owners if you think this could help. Do they run hot sometimes??
I will also try to see if one of the companies comes out with an on and off switch for the Fan. It's a cheap and easy thing to make that I'm sure WOUld REALY SELL.
Well Boner,
I got a small metal shop out here who said for $110 he will make an aluminum skid plate for my Cat. All I need to do is take the stocker to him for a template and he will program the measurements into his computer plasma cutter and presto a skid plate. Supposed to be made from 1/4" aluminum (not aluminum dimond plate.) If others are interrested after I get one made I'll take pics and post them. I'll also tell the shop to save the program for future use. I'm going to try and get it made next week.
Good Riding
Good Riding
I love the factory skid plate, but it has 2 downsides vs an aluminum/stainless steel one.
1. The factory skid has been known to flex enough when bottomed out on a pointed rock that it busted a hole in the oil pan, forceing the rider to ride home with no oil in the motor.
2. It just don't look as cool as a shiny metal one.
Customer Service #1
05-15-2020 08:46 AM
