Pro's and Con's on wheel spacers
Old May 23, 2002 | 12:52 AM
TillerTruckie's Avatar
I have a 500 4x4 and want to put rim spacers on, is there any thing that I need to know before I start. Will it help me through the mud or am I waisting my money? Just looking for any edge I can get.
Old May 24, 2002 | 11:06 AM
ttaylor's Avatar
Wheel spacers can be good and bad depending on your situation. Will spacer will make the quad wider. It is good that you are not riding in the same tracks as other ATV's. Because of this you are always making your own trail so to speak. In those situation where you want to make your own trail then they are great. In those situations where you want to follow the tracks of someone before then they will become a hinderence. Overall I think wheel spacers are great. They provide extra stability with minimal costs. I would recommend buying the ones where the spacer bolts to you existing studs and then your rim bolts to another set of studs on the spacer. If you go with the older style then there is the possibility that the studs could break because of the load.
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
