New ATV'er... have question about my 2001 Arctic Cat 500 4X4
Old Jun 23, 2002 | 10:34 PM
CANehDIAN's Avatar
Hi All,
Yesterday, I bought a 2001 a used Arctic Cat 500 4X4 (almost new - 231 miles) and everything was fine when I took my test drive yesterday. The person I bought it from said he had only taken it out a few times since he bought it in May 2001 (new girlfriend shortly after buying the ATV... Need I say more?). He hadn't taken it out at all this year.
The machine looks brand new but, today, I went out bushwacking and had some problems with it stalling and backfiring . I thought that, maybe since it hadn't been out in a while, that might be causing the backfiring problem. It seems to be idling a little low but I can't figure out why it stalls when I come to a stop.
Any ideas?
C.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 23, 2002 | 11:16 PM
mudcat47537's Avatar
It may just be a old fuel thing going on. You could drain the tank and carb and refill with fresh fuel. Also mice could have built a nest in the airfilter box, I have seen this before. Just check it out and do a service on it first before you get in to it too much.
Old Jun 24, 2002 | 10:27 AM
CANehDIAN's Avatar
Looked at the air filter box (air filter is still new) and, nothing. I'll drain the gas and see if that makes a difference.
Is there an additive I can put into a fresh tank of gas to clean out the fuel injectors? Should I bother?
Thanks,
C.
Old Jun 24, 2002 | 03:30 PM
MountainCat's Avatar
No fuel injectors here!!! [img]i/expressions/face-icon-small-smile.gif[/img] While your are at it, I would go ahead and change the oil. The idle control should be around your carbureator.
Old Jun 25, 2002 | 03:57 PM
voodoo's Avatar
I found my 98 500 4x4 did this until i did a close up exam of the boot from the carb to the engine and from the airbox to the carb. It was not correctly installed on the engine to carb end. It was sucking a little air and caused a lean condition as well as the symptoms you describe.
Mark
Old Jun 26, 2002 | 04:00 AM
Andy Bassham's Avatar
Not uncommon. Try draining out the gas (if it has the same gas in it) and putting in a fresh tank. If it persists, then you can have somebody (or do it yourself) take apart the carb and clean it out, then replace the spark plug.
Last week I pulled the carb off my uncle's 454, dismantled it and cleaned it out good. Then I cleaned the air filter and put a new plug in it. Runs like a champ again, and it ran like crap before. If its in need of this, it really makes a noticeable difference.
Cole Hadden
Jun 15, 2025 09:05 AM
Hunter100us
Oct 7, 2015 11:46 PM
Aug 11, 2015 03:42 AM
Club News and Events
Jul 23, 2015 02:04 AM
Gtsordo
Jul 13, 2015 10:38 PM
