GEAR INDICATOR LIGHT PROBLEMS?
Old Mar 23, 2000 | 10:25 PM
CANADA's Avatar
About a month ago my dumba$$ brother couldn't get the 98 454 into reverse(when it was cold) so he pulled on the lever so hard that the lever bent & the indicator light says it's in REVERSE the whole time,so when i go to start it now i have to push the lever forward HARD until the light says NEUTRAL then start it.did any1 else have any problems with putting it into reverse or problems with the indicator lights????????????
Old Mar 23, 2000 | 10:28 PM
CANADA's Avatar
P.S. the 98's do not have the start-in-gear feature
Old Mar 23, 2000 | 10:42 PM
aczr2k's Avatar
He probably just bent the lever where the reverse indicator switch is. Do some checking and rebend where the switch is and you won't have any more problems.
Old Mar 23, 2000 | 11:27 PM
BIGBADCAT's Avatar
I didn't seem to have any problems with mine when it was cold. I had a little trouble starting it every now and then. It's pretty cold natured. Damn you would think that something called arctic cat would be real good in the cold! If the bike is still under warranty make them fix it.
Old Mar 24, 2000 | 09:29 AM
BigCatDriver's Avatar
You have a point my new 2000 is very cold natured, even in Alabama. As for indicator light problems the only one that I have found is that my neutral light will not come on but its in warnty i just need to take it to get fixed
2000 'Cat 500 4x4 Warn A2500 and soon to have 27" 'Vamps
Dabears1983
Jun 16, 2015 12:17 PM
FWhitt
Jun 13, 2015 02:22 PM
generalpops
Jun 5, 2015 08:23 PM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
