custom 250SX question?
Old Jul 11, 2003 | 05:19 PM
ThreeWRacer's Avatar
Default custom 250SX question?
I have a 250SX with custom suspesion that I built my self. I got the most I could with the stock shock and shaft drive. I moved the shock mount foward to cantilever the shock more. It now has 8 1/2 inches of travel. It works beautiful. But in some situations it preloads wierd. Because the back is softer. Does any on know what kind of forks would fit the 250sx. It has the stock triple trees. Would 250r Forks fit in the trees.
Old Jul 11, 2003 | 05:33 PM
heehaw's Avatar
i dont know any that fit the tripple bit i put 250r forks on mine and i could not take them off fast enough going straight they were fine but when you make a turn the front tire just slid did noty like it one bit i asm going to try a 200x front end next after my arm hills ther 84 250r frount end sucked as for rear shock i thought of putting a 82 250r on one of mine
proud owner of
5 250sx
1 250es
1 185
1 250r
1 200s
Old Jul 11, 2003 | 05:35 PM
It did that because they were to tall. But my SX back end is a good 3 inches higher!
Old Jul 11, 2003 | 05:38 PM
Does anyone know were to find a big bore kit. And how much they cost. Ive heard of 300 kits but they are hard to find.
Old Jul 12, 2003 | 01:44 AM
heehaw's Avatar
i had 22-12.5 9 on the rear the bike just did not want to corner very good
Old Jul 12, 2003 | 04:17 PM
I went on yahoo and I can only find 300kits for dirt bikes
Old Jul 21, 2003 | 03:21 PM
valerius's Avatar
I put 350x front forks on mine. They were a straight swap, no mods necessary. They work beautifully. Look on ebay and you should be able to find a complete set with front tire and disk brake. Nice upgrade.
About a year ago I tracked down a big-bore kit for the SX. I contacted the manufacturer directly. They were very motivated to get these things off there shelves. They made me a very sweet offer on the kit. I don't recall the price. I'll try to find the email. I will also look for the name of the manufacturer.
If your interested in seeing picks of the sx with the 350x forks go to - http://f1.pg.photos.yahoo.com/valerius400
I'd love to see picks of your rear end set-up. One thing that is disappointing after my front end conversion is the stock rear end. there is no comparison between front and rear on my SX now.
Old Jul 21, 2003 | 10:15 PM
dork's Avatar
heehaw, your front end probably pushed so bad because the longer forks decreased the steering rake. but with a taller rearend it should even it out.
on the big bore kit, www.powroll.com has a smokin deal on a 2mm oversize piston with 10.5 to 1 compression. comes with piston, rings, and wristpin. normally $140, now $25. look under their sale section. i have an old 3 wheeling issue where they installed a mugen 300cc bore kit on a 85 big red 250. they appeared to be pretty impressed.
Old Jul 22, 2003 | 03:21 AM
heehaw's Avatar
well about the 250r front end i tried it and i had 25- 12.5-9 tires on the rear i go riding about 5 or 6 times every week i own 5 250sx and were i ride it is sandy and the bike just did not turn to my sat. now i have one with a 200x front end and i am total happy now were you live you may ride on hard ground and it might work for you are if you just ride straight it will probley be just fine the 200x frount in my type of rideing is the onley way to go
Old Jul 22, 2003 | 09:45 PM
I got the picsof my sx up. Click on the camera under my user picture and name on the left. The only thing is when you horse the gas the bak end is so soft it lifts up. Its a real problem when you jump because as soon as you leave the lip of the jump i usually hit the gas and it preloads the backend up and triesto endo it. The new V-force has 9.5 inches of travel and is shaft drive. I have to mess withe the shock angle to get the preload right.
