piston quetion ??
piston quetion ??
Unless the 250X is ragged, you wont be close in a drag race.
A good set of quality rings and a top end gasket set will set you bak about $75
You are going to need a repair manual to rebuild it correctly. It has all the specs for you to follow regarding clearances..etc.
The manual lays it out in basic terms how to go about replacing the rings.
exmotocrosser
09-13-2019 06:12 AM
Quadzilla Heritage
09-25-2015 01:39 PM
