would this work out?
Old Mar 17, 2004 | 07:03 PM
QUADRUNNERMIKE's Avatar
Default would this work out?
if i were to put in a 200X cam in my 84 200S, would that work out ok?
and if i did this, what other mods would i have to do?
does anyone know where i can find some aftermarket parts for my 200S?
Old Mar 17, 2004 | 08:51 PM
you around Knows? (or anyone else)
Old Mar 17, 2004 | 09:55 PM
KNOWSALOT's Avatar
The Facility
The cam from the '83-'85X is a drop in camshaft for that engine. The '86-'87 X will not work.
Everything you can do to a '83-'85 200X can be done to yours. They share the same topend and the guys who do the stroker kits on the X crank can do the same with the ones from your model.
The pocket book is the limit.
I have a little over $1600 in my 244 stroker engine..........and I haven't even gotten to the porting part of it......LOL
If you go with the X cam, go with the XR carb and intake....heck, you could use the XR cam if you wanted to. It's a bit more high strung than the X cam for most guys, but may be what you are looking for. Don't even fool with either until you get a good exhaust. Cobra still makes a megaphone exhaust for these that have a huge header pipe and if you want to keep the stock muffler....the header will work with that as well.
If you shop right, you should be able to get a new cam, carb, intake, and exhaust for around $350
Don't forget about the piston while you are in there. Wiseco makes a 10.25:1 and a 12:1 comp ratio piston kit and offers the 12:1 up to a size 67mm...........which puts your engine size at a true 204cc.....with the stock crankshaft.
Stroker cranks can be had from Powroll. That's where I have all my stroke work done. To do it right the first time, it costs a bit more, but is worth the insurance. I always have them add a NEW rod, crank bearings, and rod bearings, plus a balance procedure. It runs $400.00
They use the "shrunken rod" procedure which is tough to explain, but i can if you want to know how it's done. If you feel your rod and crank are in great shape and just want the stroke changed, it runs about $250 unless they have gone up in the last few months.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
