ATC70 Mid/High RPM problems
Old Apr 5, 2004 | 07:37 PM
dfox's Avatar
Default ATC70 Mid/High RPM problems
Mt daughter has a 85 ATC70. It starts and idles great. When you get on it it will run good for a couple seconds then start cutting out. If you let off the gas it will again be OK until you get on it again. The problem seems to be not enough fuel volume. I have changed the fuel hoses, replaced the in line filters, cleaned the tank taps, Cleaned (several times) and rebuilt the carb. cleaned the fuel valve, Cleaned the carb bowl vent, checked the gas cap vent - No help. It use to run fine then this problem started and it seem to be getting worse. I must be on the wrong track on this fuel thing. Any Ideas ??????
Old Apr 5, 2004 | 08:02 PM
HA2's Avatar
HA2
whens the last time u changed the points in that bad boy.
Old Apr 6, 2004 | 12:01 PM
dfox's Avatar
Although it did not fix the problem, I did notice a difference in the symptoms when I adjusted the point gap. I will try a new set of points. Thanks for the reply
Old Apr 6, 2004 | 06:04 PM
hondabuster's Avatar
Take it for a ride, and when it acts up, pull the choke on. If it runs better, look for things that would cause a lean condition. If theres no change, its either already too rich, or the points could be bad, or the spark plug could be giving out.
Intake leak, or low float level, would cause it to be lean.
let us know what you find.
Old Apr 6, 2004 | 06:19 PM
HA2's Avatar
HA2
putting new points in a ol 70 is a big wake up call last time well only time we did it. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 9, 2004 | 09:40 PM
dfox's Avatar
The new points did the trick. Once again it runs like a champ. Thanks for the advice.[img]i/expressions/face-icon-small-smile.gif[/img]
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
