idol probs.
Old Apr 14, 2004 | 11:36 PM
pondrunner's Avatar
Default idol probs.
the 200s is having idol problems again. it won't idol at all. its getting gas. and the only way it will stay started is by reving it up. when you stop reving it up it dies. please help im getting tied of the idol problems with it.
thanks
84 200s
85 110
Old Apr 15, 2004 | 12:35 AM
KNOWSALOT's Avatar
The Facility
Default idol probs.
Well, if the carburetor isn't dirty, I would look into the throttle cable. If it is strethed or loose at the carb top, you will always have erratic idle until it has been replaced.
You may also want to look at the slide. Check to see if it has any wear nothches where the idle screw meets it. This happens when people turn the screw inward without blipping the throttle while doing so.
dvxxvd
Feb 15, 2017 07:47 PM
trike
ATC 3-Wheelers
Sep 29, 2005 11:47 PM
PlatinumDogg
ATC 3-Wheelers
12
Apr 10, 2004 01:13 AM
StockRappy
Aug 5, 2003 11:44 AM
motorider7
KTM
22
Jan 16, 2003 04:46 PM
