200m recomended spark plug
Old 02-21-2005, 04:06 PM
Fr33ze's Avatar
Default 200m recomended spark plug
Originally posted by: catchmeifucan
It must be just flooding it. This could be due to jetting, and your float too.
It'll idle forever, and go when I giver gas. Doesn't miss or flutter at all. Doesn't leak gas outta the carb at all.( I looked inside the air filter the first couple times this happened, to see if it was soked, and it was dry)
I got 140psi cylinder compression...
When the spark gives up, I change the plug with a new one, and right away, I'm off to the races...
Would a hotter or cloder plug, quick fix this problem? I had a couple of sleds that did the same, and i went from a BR9 to a BR8 and no more plug problems...
Old 02-21-2005, 04:11 PM
catchmeifucan's Avatar
You could try the plud idea, switch brands a couple times too, and see what happenes.
plug*
Old 02-24-2005, 01:49 AM
MY86ATC350X's Avatar
plug issue my xl350 enduro was the same. make sure your choke is off lol. on my 350x plug says DR8ES-L "R" Resistor Plug.
  #15
Old 02-24-2005, 12:06 PM
Fr33ze's Avatar
Resistor pulgs... do I have to have a resistor style cap, to makem work properly?
Or, will "B8ES" plugs instead of "BR8ES" last longer? I know the B8ES is a 2 stroke sled plug, but it should still burn.
Went out for a tour yesterday and no problems with the BR9ES...YET.
  #16
Old 05-19-2006, 09:05 PM
lawnboymelvin's Avatar
the plug in my 200m is a DR8ES-L
  #17
Old 05-20-2006, 11:05 AM
medeff's Avatar
the differences between DR8ES-L and DRES is the length. L stands for long, with the shorter Plug you are farther from piston so it won't burn quite all the gas which will cause to foul, I think? also check the gap on the pulse generator (cdi) that will cause the same thing
Big bousse
09-26-2015 10:42 AM
cornermike
07-30-2015 06:37 AM
ScopeZ_
07-28-2015 01:44 AM
Ty64
Technical and How-To Articles
07-25-2015 02:02 PM
Dirtbikemike1
07-21-2015 04:13 AM
Quick Reply: 200m recomended spark plug
