200x breaking up
Old Mar 25, 2005 | 05:14 PM
ThrashAndCrash's Avatar
Default 200x breaking up
You could try to raise the needle clip 1 and see if it helps
Old Mar 25, 2005 | 05:20 PM
paulie83's Avatar
raise it to the third ring? and basically you are saying my jet is to big?? thanks a lot for ur help!!
Old Mar 25, 2005 | 06:34 PM
paulie83's Avatar
well i checked my needle and the clip was barely on i put a new clip on the second ring<stock setting> it ran fine just tried to start it again it started and then fouled the plug i put another plug in and kicked it a couple times wouldnt start pulled the plug and it was wet and black have no idea what the problem is?? is the jet to big and now that the needle is right its just fouling plugs???
Old Mar 25, 2005 | 08:19 PM
paulie83's Avatar
any one??
Old Mar 25, 2005 | 09:19 PM
  #15
dragracer789's Avatar
Your to rich, almost guarentee it. Mines ported, pipes, and has a cam and its only at 112, So you should go down to about 110.
nastyblaster100
Sep 13, 2015 01:19 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
black798
Sep 9, 2015 07:42 AM
atvcollector
Sep 8, 2015 05:11 PM
