200x 1st gear problem
i bought a 200x today and when i went to start it up and push the shifter down to shift into first gear it seemed like the was no first gear there, or like something is stopping it from getting into first gear, if you pull the shifter up it goes into second gear fine but why wont it go into first?
Originally posted by: BigRed1985
200x's have a one gear down setup? i believe my bro's was only a five speed
MOJAVEalltheway.... did you look and see if the shifter is striped on the shifter shaft? Is the clutch adjusted correctly? Do all the other gears work?
