Do u put 2 stroke oil in the crankase and if so how much...>?
The wrong oil will burn a clutch out way to prematurely for me, and the tougher you are on them, the quicker they go. You can find appropriate oil for just a $1.50 more a quart. I can get a quite a few oil changes before needing a new clutch by avoiding the auto oils.
I got to admit that my riding isnt very hard on my YTM200 and BigReds. No manual clutch and no rear suspension kinda keeps me from beating on them. But I do go through so much water that I change my oil after every ride since it gets milky. Thats why I use 10w30 in them to lower to oil costs. And I feel the same way about my warrior as you do about your machines: it deserves the best. Ho yeah and the same about my gf!!
You should listen to this guy,it sounds to me like he knows what he is talking about. I am a professional auto tech for 17 yrs. and I can tell you with authority that all oils are not created equal and using the wrong oil can lead to costly repairs.
#15
Originally posted by: JkAss
What bike do you have? To see how much oil you need check a manual or call your local dealer. My 85 250R has a screw on the side of the case I remove. I put oil in the fill hole until it comes out of that screw hole. It is about 650ml, I believe. Someone please correct me if I am wrong. I have done it like this forever and haven't fried a bottom end yet, but it doesn't mean I'm right.
exmotocrosser
Sep 13, 2019 06:12 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
