help 200m
Old Jun 23, 2006 | 09:29 PM
farmerman's Avatar
Default help 200m
i just bought a 200m it wont idle sounds like carb floods same at half throtle it will stall but at high rpm it runs good for a while just wondering if the fuel srew needs to be adjusted or somthing else
Old Jun 23, 2006 | 09:58 PM
lawnboymelvin's Avatar
Default help 200m
i had same problem, make sure the needle that goes into the carb is on the 3 clip and try moving the needle jet on the carb if you want to go what the manual says it says that needle should be turned out 2 1/4 out from closed fully. also try the idle screw. i have a 200m to but it smokes awfully bad, post some pictures of your 200m would love to see it!
Old Jun 24, 2006 | 01:23 PM
farmerman's Avatar
Default help 200m
anyone know the true spark plug number dont know if i have right one
Old Jun 24, 2006 | 01:36 PM
Default help 200m
the right plug is DR8ES-L
Old Jun 25, 2006 | 09:57 AM
farmerman's Avatar
Default help 200m
thanks lawnboymelvin i tried the spark plugs you said and it ran good but when revving it my thumb throttle came apart lol
Old Jul 2, 2006 | 11:35 AM
farmerman's Avatar
Default help 200m
i just got the thumb throttle fixed on thursday and fouled both plugs by saturday does anyone have pictures out of a manual for adjusting the carb they could email me my email is johndeere1650@hotmail.com i dont understand what this clip is on the needle
Old Jul 2, 2006 | 12:42 PM
HondaAtcRoxz's Avatar
Default help 200m
On the top of carb there is something you can screw off. Take that off and then there is a needle sticking out of the botom of it. Take the throttle cable out then you will just have the peice with the needle sticking out. There is a clip in the bottom of it that you need to take out with a pear of pliers. Then pull the needle out and there is a little clip on it with 5 spots to put it. Putting the clip higher on the needle with lean out your feul mixture. Putting it lower will richen it up.
HOPE THIS HELPS!!!
Old Jul 2, 2006 | 03:25 PM
farmerman's Avatar
Default help 200m
thanks for explaining it in detail i checked it and it was on the top setting but its still running rich any other adjustments on the carb or is the jetting totaly wacked out
Old Jul 2, 2006 | 06:50 PM
Default help 200m
sounds like your needle seat is messed up lettin too much fuel in.
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
Bob427
8
Jan 23, 2013 07:35 PM
jonnyneutron
ATC 3-Wheelers
May 27, 2006 10:00 AM
MyHatetredBleeds
ATC 3-Wheelers
Jun 1, 2005 12:40 PM
WeaponM200
ATC 3-Wheelers
10
Aug 2, 2004 01:15 PM
