problem with a 200s
it smells a little like gas. i have shut the gas off all i can. i think my problem is in the fireing. i have spark
but it feels week., but all i have ever felt have been week even when new. could this be the
problem?
problem?
i noticed today that the gas screw on the carb was just about screwed all the way out i screwd it in where it should be and it runs good i rode it for about 30 min. i think the problem was the screw was vibrating out when i was riding it i put a longer spring in it and it works fine now
what about firing on theses does any of them have much fire or are all of them weak
mine is in time
mine is in time
#15
still having promblems with carb. when i start it, it will idel but when i give it a little gas it dies.
when i do get it runing it sounds like it is starving for gas. carb. is clean and not stoped up, or the gas line either.
#16
#18
im having the same problem with a 185s i picjked up for dirt.but i didnt have a air filter on it just the screen when i tried to crank her.she will run a while then die and you pull the plug its wet with gas. any more info on this would be apprecieated thanks.
#19
Matt: Moving the clip up will lean your bike out. If you can not lean it out enough your main jet is too big or your needle seat is wallowed out.
300ex: Clean your carb out well then try to run it again. If it still runs like that and the plug is wet with gas move your clip up to lean it out. If it is wet with oil you have a hole nother problem!!!
RticKwad
Jul 21, 2015 03:00 PM
