winding?pull rope problems
Old Aug 21, 2006 | 04:26 PM
hondaman300ex's Avatar
Default winding?pull rope problems
can anyone tell me how to get my pull rope assembley back on without it un
Old Aug 22, 2006 | 12:47 PM
lawnboymelvin's Avatar
what does un mean? and what are you asking? how to get the rope back in the pullstart without the spring unwinding or how to get it back on the motor? well if you want the string back in here is the steps: get all the old rope out. if the spring is still loaded let it go slowly dont just let go of it. take the pin out on the top and remove all that housing. pull the wheel out slowly and you will see spring.. dont touch it! lol. put new rope in and tie the not at the end in the hole. rap the rope around the wheel then place it back inside. pull rope end up in little notch on the rope wheel. turn the wheel until it gets hard then turn 2 turns clockwise. pull rope end threw hole on metal housing and put pull handle on and its ready to go. if you buy a manual it tells you in there.
Old Aug 22, 2006 | 03:05 PM
thanks for the info i finally figured out i had thr rope in wrong. but anyway thanks. ive got a 185s im restoring.any info on carbs would be apprecieated. im getting no fuel.
Old Aug 22, 2006 | 09:54 PM
clean the carb out real good with carb cleaner. try adjusting the air mixture screw on the bottom of the carb or move the clip up a notch or down and see what happens.
WilliamBos
Sep 30, 2015 08:08 AM
kdubben
Jun 30, 2015 03:13 PM
DOAinNY
Jun 11, 2015 10:34 PM
mpcop077
Jun 10, 2015 08:30 PM
generalpops
Jun 5, 2015 08:23 PM
