how to identify a 250R ??
here is the info.
250r atc
Look at the steering stem portion of the frame where the lower triple tree goes through it. You may have to use sandpaper if it has been painted over, but there is a serial number stamped right there. Write it down and then use the search feature here on the forums and type Honda ID under the ATC section. I have several old posts that go into detail with every serial number from every Honda ATC ever built for mass production the USA.
1981-1984.................248cc, AirCooled, 5 Speed, Manual Clutch, Right Side Chain Drive
Frame ID Numbers
1981....JH3TB060*BC000020 and up
Gold Painted Steel Wheels, Red Engine, Red Fork Legs, Solid Front Brake Disc, Drum Rear Brake, Black Seat, Black Fork Boots
1982....JH3TB060*CC100001 and up
Gold Painted Steel Wheels, Red Engine, Red Fork Legs, Slotted Front Disc, Slotted Rear Disc Brake, Black Seat, Black Fork Boots
1983....JH3TB060*DC200001 and up
All New Body and Fuel Tank Design, Gold Anodized Aluminum Wheels, Black Engine, Polished Fork Legs, Blue Seat, Pro-Link Rear Suspension, Headlight Guard Standard Equipment
1984....JH3TB060*EC300003 and up
Same unit as 1983 with a new design 250R logo on side of rear fender.
Engine ID Numbers
1981....TB06E-2000033 and up
1982....TB06E-2100004 and up
1983....TB06E-2200005 and up
1984....TB06E-2300003 and up
250r atc
Frame ID Numbers
Engine ID Numbers
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
