atc 200 trans. ?
Old Jun 13, 2008 | 09:25 PM
LONG TRACK's Avatar
Default atc 200 trans. ?
I purchased an '82 atc 200 Wed. and am having a blast with the five year old boy. I have 5 acres, so we have enough room to have some fun. It runs great and drives out pretty nice. The tranny seems to have an issue or two though. It is five down and when you shift from gear to gear the shifter goes down and stays there instead of coming back up like it should, so have to slightly push it back up where it goes and then it will take off in that gear. It's almost as though it's stuck between gears. Anything I can do to fix the problem. Also the clutch seems to slip when you give it more than half throttle or when climbing a small hill. Can this be adjusted and if so how? Thanks for any help.
Old Jun 14, 2008 | 07:17 AM
HondaMechanic's Avatar
This is how to adjust the clutch ..
This spring centers the gearshift , sounds like yours is broken or gearshift spindle is broke ..
Old Jun 14, 2008 | 08:47 PM
LONG TRACK's Avatar
Okay, thanks. I've printed this off and I'll dig into as soon as I can and let you know what I've found.
Old Jun 27, 2008 | 11:20 AM
2ron2dude's Avatar
Hi Hondamechanic,
Been reading your replies, and i am really impressed on your expertise!
I just acquired an 83' 200atc and changed the engine oil. However i cant seem to find drain for the transmission. I was thinking of changing the gear oil too if it does have one. I am pretty new to ATC's and the previous owner didnt even know what model of 200ATC it is. I have a VIN #JH3TB051-GDC3237 if that would be of any help to identify the model. This model has 5spd , hi-low and chain drive.
Old Jun 27, 2008 | 03:50 PM
The motor and transmission use the same oil , it is the 24mm oil plug on the lower left just in front of the gearshift .. They don't use an oil filter they use a screen that's in the same hole .. The 1983 ATC200E uses a chain drive so there's no gear oil , the 1984 ATC200ES is shaft drive and does use gear oil ..
The serial number you have here is only 15 digits (and the "G" doesn't look right , are you sure it's not a "9") and should be 17 , your year code leter is the "D" which is 1983 ..
Old Jun 27, 2008 | 04:46 PM
2ron2dude's Avatar
thanks man, i have too recheck the vin#. btw, this atc also has an electric & pull start with hi-lo gear. could this be an ATC 200E?
Old Jun 27, 2008 | 05:48 PM
Yes it is an 83 ATC200E .. Here is a pic of it..
Old Jun 27, 2008 | 05:55 PM
2ron2dude's Avatar
wow! looks exactly like it. thanks very much, and have a great weekend!!
Kdgncop
Jun 17, 2015 09:37 PM
gearhead17
Sep 9, 2004 01:33 AM
NRATH
KTM
10
Jul 5, 2002 11:36 PM
DAKOTARAPTOR
Apr 20, 2002 09:04 PM
foots22
Oct 5, 2000 01:01 AM
