Why cant I time this 200s?
Old 03-25-2009, 11:02 PM
200sATC's Avatar
Default Why cant I time this 200s?
Was wondering if i was doing this correctly, trying to set the timming on my 200s. I set the timming mark on the flywheel on the T line and checked the sprocket on top which is not linning up and will not.. the mark either falls one ahead or one behind..now It will line up with the f line but not the t..what is going on here??
Old 03-25-2009, 11:10 PM
SMFREY's Avatar
You should be setting on the F
This should also be checked with the engine running at about 1,400 RPM +-100 RPM
Thanks
Ray
Old 03-25-2009, 11:17 PM
200sATC's Avatar
Alright then so what does the t mark line up with? Is it the pick up ?
Old 03-26-2009, 09:59 AM
SMFREY's Avatar
Valve adjust and cam timing
That is top dead center
The F is advanced or before top dead center
If you set to the T your timing would be retarded
Thanks
Ray
Sjrpp
05-02-2023 03:59 PM
Sjrpp
11-15-2019 09:59 PM
Sjrpp
06-02-2019 07:25 AM
95wolv
07-17-2015 08:13 PM
timster911
07-13-2015 01:57 PM
Quick Reply: Why cant I time this 200s?
