big red exhaust
big red exhaust
is it ok to run a 250es big red with a streight pipe, i already have a pipe i built but i just wondered if it is ok to use it without hurting anything. it follows the same route the stock muffler follows but it is just a piece of pipe. it runs fine with it on but it seams to get hot after you ride it for a wile like on an open road or somthing no matter how easy you ride.
i agree ... running lean will also make the engine run hotter ... if the pipe is long enough it will heat the air before it gets back to the valves and not bend them by cooling them off to fast... id would do a plug check IMO if you wanna stay with the pipe
Administrator¿
Resident Killer!
"A little nonsense now and then, is relished by the wisest men". Willy Wonka: 1971
Cigars! Earth ne'eer did breed such a jovial weed.
A Tiger Doesn't Lose Sleep Over Opinions of Sheep
Resident Killer!
on
mrtidy
02-03-2016 05:00 PM
Quadzilla Heritage
09-25-2015 01:39 PM
