Does this sound like a clogged crankcase breather? Honda ATC 200
Old Sep 25, 2011 | 09:58 AM
DigitalDwarf's Avatar
Default Does this sound like a clogged crankcase breather? Honda ATC 200
I took my Honda ATC 200 into the dunes for 2 hours, came down and parked it. I left it for ten minutes came out and there was a puddle of oil on the ground. I noticed the oil was leaking out a little hole on the bottom of the pull start case. Took that apart and tightened the bolts. I then took it back up for 15 minutes. When I shifted into second gear 15 minutes later the trike bogged down and shut off. I looked at the engine and it was smoking (like it was going to start a fire ). Took it back down and oil started leaking out again and the engine smoked for awhile longer with the trike off.
I am thinking to oil coming out of the pull start is because of a seal/o-ring behind the stator, but no idea why it would bog down and shut off and then smoke? The smoke seemed to be coming from the top of the engine.
Could this be caused by a clogged crankcase breather?
Old Nov 10, 2011 | 08:38 PM
nickdodd25's Avatar
It verywell could be the oil is just shorting out the stator and killing it. but how much oil did u loose? And when u say boggs out does it act like u hit the kill swich or is it just running out of power untill completly stops. If it lost enough oil from the leak and getting ran low u could be heat seizing the motor. wich means motor is going to be junk. And if smoke is coming out the top of the motor then the breather prolly is not clogged.
Nick
ScopeZ_
Jul 28, 2015 01:44 AM
Captjay
Jul 23, 2015 12:33 PM
Jul 22, 2015 05:00 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
