250r and 200X - Whats the difference?
In honda model numbers, X means 4 stroke. R means 2-stroke. 200x and 250r are totally different. No parts that I know of will interchange. Also the R will have a red plastic gas tank. The X will have a white steel, same as 350X. The swingarm will be gray on the X and gold on the R. The wheels should be silver on the X and gold on the R. The X is air cooled and the R has radiators. There are also many other differences. Hope this helps.
'83-'85 200X was a 5 speed and had power.
'86-'87 200X was a 6 speed and had much more power. Totally different engine than the '83-'85.
The serial number is behind the headlight on the steering head. You can use the first 7 numbers of that serial number to determine what he has.
200X--JH3TB05
250R--JH3TB06
You can use the 9th character of the serial number to determine the year model. The following year model codes apply whether it is a 200X or a 250R
D-1983
E-1984
F-1985
G-1986
H-1987
This is the easiest way to determine what you have considering that most three wheelers these days have a variety of mixed parts added over the years. You can't always go by appearance and colors.
200X--JH3TB05
250R--JH3TB06
D-1983
E-1984
F-1985
G-1986
H-1987
1985 Honda ATC350X....
Serial number..JH3TE0801FM000001 thru M******
Engine number..TE08E-5000001 thru 5******
1986 Honda ATC350X....
Serial number..JH3TE0806GM100001 thru M******
Engine number..TE08E-5100001 thru 5******
The only differences recognized by Honda between the two year models are body plastic color only. The same engines were shared amongst both years.
The characters that I have in Bold are the characters that designate it from an '85 to an '86.
Not quite as interesting as determining something like a ....ATC185..LOL
Hope you can use the numbers,
Patrick
Patrick
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
1985, 1986, 200x, 250r, ddifference, difference, differences, engine, faster, gas, honda, plastic, put, tank, year
