'82-185s...I took the Flywheel off....Now no spark.
Help....
I have an '82 honda 185s atc. Did some serious muddin' with it on the week-end and I noticed the light was dimmer. Every once in a while it would flash really bright, so I took the fly-wheel off in order to clean the connections and check the stater plate ( I think that's what it's called???) . BAD MOVE... Had a b!tch of a time getting it off. All I thought I did was clean up teh connections and lightly sandpaper the magnets on the Fly-wheel...put it back together - no spark!!. Took it back apart and noticed a mark on the top coil (probably an errant move with the scredriver getting the f-wheel off). 3-4 little copper wires are damaged...Is this the problem???? Can I just glob some solder in there??? or is it new stator time???
Any help would be appreciated....
Thanx
No...I used it for prying to get a that nut off...then I didn.t have the patience to make a puller, I thought a little playing with it and would pop right off. After about an hour- i made the puller (valuable lesson learned !) and popped the flywheel off no-prob. Now I notice that 3-4 copper wires are cut...Anyway got a new stator on order- now I need to know how to put the sucker in... Can I just take out the bolts holding the stator and pop the other in??? Or will something shift in there and screw the timing all up??? thanx for the help....
Scooter's Shop
23
10-22-2015 08:04 PM
