Please Help
Shopping for the best 500cc 4x4 does anyone have any great advise. Will be an all purpose machine, I think that I have come to the conclusion that I want the IRS for maximum ground clearance, tight technical trails, etc. I know I am giving up some stability, and sportiness. I would like to eventually attach a plow as I now have about 18" of snow.
Does anyone have any pro's or cons in regards to Polaris Sportsman 500 or the Arctic Cat 500? I know they are both heavy, but they seem to be the only IRS units in the 500cc class.
I purchased a used 2003-AC 300 4x4 a couple of weeks ago as a unit for my girl friend to ride, not overly impressed with that rocker shifter, but other than that seems to be a decent machine. Any pro's and cons would be greatly appreciated, Thanks.
Keep in mind, on Polaris 4x4's, engine breaking is ONLY on the rear wheels and this can surprise you when going down a steep hill and the rear wheels lock and you slide sideways...The front wheels will only engage when the rears loose traction and spin. I know as I wrecked a SP700 on a very steep hill with gravel..Great quads, just need to know their limitations.. My Cat has engine breaking on all fours.. just an FYI..
ColoradoGrizz, is correct the engine braking is only on the rear wheels (I did not know the cats had them on all four). He is also correct in knowing what your machine can and cant do. This is why I am very hesitant in "lending" my machine to anyone that does not have experience, unless its just for a spin in an open field. Engine braking is not a new concept, some trucks have Jake brakes (Engine braking), and others have grade retarders (transmission braking). The most important think is to become familar with your machine, and keep in the back of your mind that medical costs and repair costs can be mighty expensive. Have Fun, and ride safe.
I've been riding an 02 Cat 500i with 5 spd manual for almost two years now. You get used to the rocker shifter. Think of it as a Harley shifter... Actually, it's very nice when you have big muddy boots on. Cat also sells a conventional shifter for $15.
Downhill braking is unreal with the manual. Put it in 1st low, and it just crawls. Does brake all 4 wheels, too.
