Time is drawing near...
Time is drawing near for me getting and ATV and I still haven't actually made a choice yet. My 2 choices are the Big Bear and the Kodiak. Both 2wd/4wd.
Big Bear 400 4x4 = $4,595
Pros:386 cc's, cheaper than Kodiak, semi-auto. w/ reverse, 2wd/4wd, 9.7" of ground clearance, 4 gallon gas tank (compared to others its bigger), and 556 lbs.
Cons: None so far
Kodiak 400 Auto. 4x4 = $5095
Pros:Independent Rear Suspension (IRS), 401 cc's, 2wd/4wd, 10.8" ground clearance, 4.0 gallon gas tank, 578 lbs.
Cons: No low range (but doesn't mean I would need it does it?)and auto...slipping?
Tell me what you think.
Cons: None so far
